  2. Allegro X APD
  3. Vias are gone in 3D Cavas
  • Subscribers 69
  • Views 9997
Daeyoung Kim
Daeyoung Kim over 3 years ago
All vias are not displayed in 3D canvas whereas they are shown in 3D. The design layout is made by Allegro Package Designer+.
This is 4-layer(1-2-1) design, and each padstack is defined as "micro-via" and BB via.
Appricated any advices or tips to show them properly. Thank you!
  • TCHA
    0 TCHA over 3 years ago
    If none of the vias are visible in the 3D canvas, it could be that the Vias option is not selected in the 3D Canvas Filter dialog box. Make sure all options are checked. You can take a look at the below article.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006DeSGUA0
    This is the contents of the article:
    When I open my design in the 3D canvas, I cannot see clines and vias. Is there a setting I need to enable?
    In this case, the design has a cutout. Cutouts effectively remove clines and vias. The cutout here is nearly as large as the entire board, which is why you are not seeing clines and vias in the 3D canvas.
    You can view the cutout from Display > Color/ Visibility > Geometry > Board Geometry.
    Delete the cutout from the board to be able to view clines and vias in the 3D canvas.
    Note: Another reason for the missing objects from the 3D canvas might be that the options are not selected in the 3D Canvas Filter dialog box. Make sure all options are checked.
    This is from 17.4 version
    This is from version 17.2
  • TCHA
    0 TCHA over 3 years ago in reply to TCHA
    @Daeyoung Kim can you provide an update on this? Is the issue resolved?
  • Daeyoung Kim
    0 Daeyoung Kim over 3 years ago in reply to TCHA
    HI TCHA,
    Negetive! I already checked all the entities to show in 3D canvas as you can see below, but still no vias are visible.
    The funny thing is that vias are shown when I only selected Outer Layers
    Are there any other suggestions or tips?
    Thank you.
  • TCHA
    0 TCHA over 3 years ago in reply to Daeyoung Kim
    @Daeyoung Kim, since debugging this issue requires data exchange, we will contact you through a different channel.
