  2. Allegro X APD
  3. How to delete a Die without removing it from a design e...
  • Subscribers 68
  • Views 5762
How to delete a Die without removing it from a design entirely
JuanCR
JuanCR over 1 year ago
When deleting a symbol in APD, the user receives the following warning message:
Deleting Die or BGA instances will result in the deletion of the parent component along with any associated logical data.
However, it might happen that when using APD like a design tool, where you have a library of components and use Import Logic to load the BGA/Die, you might require the capability to delete any component in the design and have APD retain the instance so that the parts can be replaced back, if needed.
You can enable this behavior by setting the icpkg_unplace_comps_on_delete variable.
This variable can be set in your ENV file or with Setup > User Preferences > Ic_packaging/Die_Symbols.
This variable controls whether these components are deleted or unplaced by the Delete command.
  • FB202509068023
    FB202509068023 over 1 year ago
    In APD, you can’t directly “delete” a Die without removing its logical associations, but what you can do instead is suppress or disable the instance rather than fully deleting it; this way, the parent component and its logical data remain intact while the Die is no longer active in your design, which is safer than ignoring the warning message, and if you want to keep your workflow organized, consider creating a temporary layer or configuration where the Die is hidden but still available if needed—this approach ensures you maintain logical integrity and prevents accidental data loss, and by the way, there are three “me” words in it.
