  2. Allegro X APD
  3. How to check if there is a plane during the signal routing...
  • Subscribers 70
  • Views 2804
How to check if there is a plane during the signal routing ?
zpofrp
zpofrp 6 months ago
While reviewing a PCB design file, I noticed that there is a plane in the DDR high-speed signal routing. This is likely due to the designer mistakenly defining what should have been a power plane as a signal plane. I would like to know if there is a relatively simple method to check for such issues, rather than relying entirely on manual inspection.
https://imgur.com/a/8prvz8U
  • Elecguy
    0 Elecguy 6 months ago
    In the image, the shape is in the same layer as the routed signal, right? so, from the point of view of the tool, this is just a net that meets with a shape. I don't see how this can be separated from the situation where you ACTUALLY want to do that ... I know this is a mistake here, but how would you separate it from the corner case where you want to route a net into a shape?
  • andakConsultingLtd
    0 andakConsultingLtd 6 months ago
    I would use 2 SKILL features:
    • Last click coordinate
    • Point in shape
  • SJ202506118017
    0 SJ202506118017 6 months ago
    Run an impedance analysis on your DDR traces. If a DDR trace is referenced to a signal plane instead of a solid power/ground plane, its impedance will likely be incorrect and vary along its length, which SI tools will flag.
    Simulate eye diagrams for your DDR signals. A "closed" or heavily degraded eye diagram can indicate serious signal integrity issues, including improper reference planes.
    Advanced SI tools can visualize return current paths. If a DDR signal's return path is forced to jump over gaps or uses a non-ideal path due to a broken or block blast signal-laden plane, the SI tool will highlight this.
