  2. Allegro X APD
  3. Automatic net assignment between one symbol and multiple...
  • State Verified Answer
  • Subscribers 68
  • Views 3274
Automatic net assignment between one symbol and multiple symbols
bdc66a938f164d
bdc66a938f164d over 1 year ago
In `project.mcm` I have one symbol that has >300 pins, and I have >300 symbols with 1 pin each. I want to use the automatic net assignment tool to map them. Is this possible?
When I open the tool, it asks me to select the source, and I click on the symbol with many pins. So far everything works fine. Then it asks to select the destination. Here, however, I cannot select the other symbols, not even one of them. When I tyr to select, Allegro says `(SPMHIS-246): No pins matching specified component class in selection set. Select pins again.`. I believe that this is due to the fact that the symbol with multiple pins (which was given to me) is defined such that it has
Component Class: IC
Device Type: DEVICE_1
Die Type: FLIP-CHIP
and the symbols with 1 pin are defined such that
Component Class: DISCRETE
Device Type: DEVICE_2
I don't know if this is actually the issue, and how to change the definition of the discrete component into an IC component to fix it.
  • bdc66a938f164d
    bdc66a938f164d over 1 year ago +1 verified
    I copy-pasted this post into Copilot and it gave me the answer. Just for future reference: 1. Open "Logic/Edit parts list...". 2. Change the class of the desired components. It was that simple.Then…
  • bdc66a938f164d
    +1 bdc66a938f164d over 1 year ago
    It was that simple.Then the automatic net assignment worked out of the box.
