  2. Allegro X APD
  3. Display Bump Pin Numbers APD 2023
  • Subscribers 70
  • Views 2312
SB202512083449
SB202512083449 10 months ago
I would like to display the bump pin number,
Below is an example with and without the pin number showing on the same file:
I've tried a lot to things but nothing seems to work.
Shai
P.S. the one who sent me the photo with the pin numbers don't know why it works for him.
  • Master Shifu
    0 Master Shifu 10 months ago
    Hi Shai,
    Try Display > Design Parameter > Display tab and check Display embedded names section. Enable "Pins #s" from other labels. This shall enable Pin numbers along with netnames. If you are not able to get this option then likely you are in older hotfix/ version.
    Rishi
