  2. Allegro X APD
  3. Electrical Net Classes Import Using technology file (.dcfx...
  • Subscribers 69
  • Views 1876
Electrical Net Classes Import Using technology file (.dcfx, .tcfx)
AnanthVedalaLM
AnanthVedalaLM 8 months ago
I'm trying to import The net classes in APD from a technology file with extension (.dcfx and also tried with .tcfx) The spacing and Physical Netclasses are being imported but not Electrical Net Classes, is there any default setting that we need to change in the APD Constraints Manager or is there any other issue
  • Master Shifu
    Master Shifu 8 months ago +1
    Did you check while exporting the technology/constraints , the contents has Electrical constraints selected ? technology file will import just the netclass definitions, if you import the constraints the…
  • Master Shifu
    0 Master Shifu 8 months ago
    Did you check while exporting the technology/constraints , the contents has Electrical constraints selected ? technology file will import just the netclass definitions, if you import the constraints the nets will also be populated if the netname matches the destination design.
  • AnanthVedalaLM
    0 AnanthVedalaLM 8 months ago in reply to Master Shifu
    Yes, i have checked the ElectricalCset check box while exporting, i was facing the issue for a different reason and the issue got resolved.
