  2. Allegro X APD
  3. Connecting to APD from external process to execute skill...
  • Subscribers 69
  • Views 1863
Connecting to APD from external process to execute skill code
SV202603065248
SV202603065248 7 months ago
Im looking for a way to connect to an existing/active APD session from an external process and executing skill within that APD session. The idea is to create this communication link between our custom workflow tool and APD to streamline execution. The forums point to using MPS (message passing system) but there isn't much documentation on this. Could you pls point me in the right direction.. Im looking for documentation or code samples.
  • JuanCR
    JuanCR 7 months ago
    Can you describe a bit more about how you are planning to connect or what your setup is?
  • SV202603065248
    SV202603065248 7 months ago in reply to JuanCR
    Thanks for the response. Here's the setup in more detail:
    * Environment: Windows only, single user, single APD session per machine. APD is running interactively with a design already open — I need to attach to that live session, not spawn a headless / -nograph batch APD. (I'm aware of the -s script.il / batch route; it doesn't fit this use case)
    * Custom application running as a separate process: We have an in-house desktop tool written in C++ (with some Python) that the user runs on the same machine as APD.
    The user clicks a button in our tool → that needs to trigger SKILL execution inside the already-running APD session → we need the return value back in our tool.
    * SKILL calls can be  Short one-line expressions, e.g. (axlDBGetDesign), or pre-registered SKILL function with arguments. In both three cases we need the return value passed back to the external process (not fire-and-forget).
    What I've looked at: Cadence documentation and several forum threads — MPS looks like the right primitive, but I can't find a worked end-to-end example of a Windows C++ (or Python) client exchanging messages with a running APD session, including how the APD-side listener is set up and how responses are returned.
    ipcBeginProcess — this seems to go the other direction (APD spawns a child), so I don't think it fits.
    What would unblock me: A minimal working example of MPS between an external Windows process and a live APD session (both the SKILL side and the external-client side), or
    Confirmation that MPS is the right mechanism for this pattern and pointers to the authoritative reference, or
    If MPS isn't the recommended path for my use-case on Windows, feel free to point me to the mechanism Cadence recommends for this.
  • GC202610128040
    GC202610128040 1 month ago
    MPS seems like an interesting approach for this. Has anyone tried using it to communicate with an already-running APD session and execute SKILL code from an external Python or C++ application? horror games
    I'm particularly interested in how the connection is established and whether there's a way to retrieve the execution results or errors from APD. Any practical examples or pointers to the relevant documentation would be greatly appreciated.
    Thanks!
