  2. Allegro X APD
  3. Die Text in Problem
  • Subscribers 67
  • Views 18087
Die Text in Problem
archive over 19 years ago
When importing die information into APD using the die text in wizard, it automatically assigns an incremental subscript to the net name, when i have more than one pad with the same net name.. e.g if i have a number of VSS1 pins it changes them to VSS1_1, VSS1_2, etc.  It only does this with some nets (not all) and i'm not sure what is causing it... can anyone help?
Thanks in advance
Gaz
Originally posted in cdnusers.org by Gaz
    Do some of the imported nets exist as both upper and lower case? (vss2 and VSS2)
    -b
    Originally posted in cdnusers.org by BillAcito
    No, they all exist as uppercase only. One other factor is that the BGA (which has been created before the die import) already has the correct net allocation, so the nets already exist in APD before the import. Out of several supplies only one is affected by this problem, and i'm confused as to why?
    Thanks for your help.
    Gaz
    Actually on double checking i found that the nets existed in the database in lower case as well, removing this has solved the problem.
    Thanks for the tip.
    Gaz
    Great. Glad I could help, Gaz.
    Also, here is another option: I think the following env variable
    set textwiz_ignore_net_name_case = 1
    will get the DIE and BGA text-in tools to ignore case, so you don't have to edit your files. This variable is hidden (not in user preferences) because of the obvious impact. As you know, in the PCB/Packaging space, nets names are case insensitive (why the tool was adding the _1). In the IC/DIE space, they [i]are [/i] case sensitive, so we made the import case sensitive as well (error on the side of caution).
    Bill
    I should point out, this assumes 15.7 code. Not sure when the option was added.
    In the next release, "case-insensitive" is planned to be a netname option when you set up the columns in the text-in wizards, so the variable will no longer be needed.
    Bill
