  2. Allegro X APD
  3. Adding plating lines in BGA package
  • Subscribers 67
  • Views 14736
archive over 19 years ago
Is there anyway to automatically add plating lines in APD 15.7?.... i am trying to add plating lines for an etchback process, is there anyway to automise this?
Ghazanfer
Originally posted in cdnusers.org by Gaz
    archive over 19 years ago +1
    I am assuming you are referring to adding traces within the etchback tool? (Manufacturing-->Etchback) The add trace is manual. Shorting schemes and design practices vary by such a great degree customer…
    The add trace is manual. Shorting schemes and design practices vary by such a great degree customer to customer, it would be very difficult to add automation to the trace add that would cover all of them (e.g. what rules should the tool use to determine the best location for the short? closest approach? most available space?)
    Once placed, the tool does automate the creation of the mask openings, based on user defined spacing parameters.
    Bill
    Originally posted in cdnusers.org by BillAcito
