  2. Allegro X APD
  3. find net in constraint manager and it will show this net...
  • Subscribers 67
  • Views 15284
find net in constraint manager and it will show this net in mcm file
archive over 18 years ago
I would like to know if have way to find net in constraint manager and it will show this net in mcm file.
Like the negative way, if we show net in mcm file, it is shoe this net in constraint manager.
Originally posted in cdnusers.org by uriya
    You should be able to use Edit->Find (Ctrl-F) to find an Object in the Constraint Manager, once you've found it select the net/xnet object and Right Mouse Button select Select - this should select the object in APD/Allegro/CDNSIP
    Originally posted in cdnusers.org by andrewjw
    it is work... Thank you
