  2. Allegro X APD
  3. Could I assign hostname to env file?
  • Subscribers 67
  • Views 14774
archive over 18 years ago
Hi! Folks
    I would like to add a path in the script path.
For example, set SCRIPTPATH = \\rd-lab-nt59/apd
    when I run the command "script", then click "Library", the script file was found, but I cann't "replay" it. It show "E- File does not exist: //rd-lab-nt59/apd/4l_artwork.scr" in the command line.
Doesn't APD support hostname path?
thanks
Originally posted in cdnusers.org by chaochia007
    It should. This looks like a permissions problem.
    Any luck since your initial post?
    Originally posted in cdnusers.org by BillAcito
