  2. Allegro X Capture CIS
  3. Arrows now show up on symbols; don't want this
  • State Verified Answer
  • Subscribers 50
  • Views 8069
Goblin60
Goblin60 over 15 years ago
 All,
I did a software upgrade and now my symbols show arrows on the inputs/outputs. I can see the arrows are identifying my pin type assignments. In my library, there are no arrows. How can I shut the arrows off on my schematic?
  • steve
    steve over 5 years ago in reply to KADcad +1
    You can also access this inside the Tools from Options - Extended Preferences - Designs and Libraries, untick the box for Draw arrows on part input pins.
  • oldmouldy
    0 oldmouldy over 15 years ago
    I guess that you are using Capture, or CIS, 16.3? Close the product down, in the Capture.ini file find the DrawPinArrows entry, set the "=" value to False.
  • KADcad
    0 KADcad over 5 years ago in reply to oldmouldy
    I encountered the same issue with the trial version of CIS 17.4-2019.  Is editing Capture.ini still the solution?
  • RFinley
    0 RFinley over 5 years ago in reply to KADcad
    Yes.   That's it.
  • steve
    0 steve over 5 years ago in reply to KADcad
  • KADcad
    0 KADcad over 5 years ago in reply to steve
    Thanks, all. I used Steve's 'untick' suggestion.
