  2. Allegro X Capture CIS
  3. increasing page size
  • Subscribers 51
  • Views 32191
gauravmohta
gauravmohta over 14 years ago
 hello,
i am in beginer in orcad capture. I am using version 16.5 . Basically the schematic which i intend to draw  is larger than the page size in terms of area.
Is there any method to increase the page size? if yes then how? and if no, then what how do i fit my large schematic into small orcad page??  please reply.
regards,
gaurav mohta
  • oldmouldy
    0 oldmouldy over 14 years ago
    Existing Pages: go to the page in the Project Manager window, right-click>Schematic Page Properties, Page Size tab.
    For a new Design, page defaults, Options>Design Template, Page Size tab
    Don't feel compelled to fit everything on one page, use the Off-Page Connectors to connect pages in flat designs, Hierarchical Ports to connect the hierarchy in Hierarchical designs.
  • Remdale
    0 Remdale over 5 years ago in reply to oldmouldy
    Hi oldmouldy.
    I'm using Orcad Capture 17.4 and still it seems there's the same problem across different versions of Capture. Whenever I try to change the page size, nothing happens. It does change in the settings, but the actual size of the schematics area stays the same. What should I do to fix the problem?
  • AvengerThanos
    0 AvengerThanos over 5 years ago in reply to Remdale
    Make sure the software is updated with hotfix S018.
    In 17.4 capture goto - Options - schematic page properties and you see the below window. Under custom, you can define the required page size in mm/ inches.
