  2. Allegro X Capture CIS
  3. Page numbering on Hierarchical blocks
  • State Verified Answer
  • Subscribers 54
  • Views 21735
Quist
Quist over 14 years ago
Is it possible to, in an automated way, add the page number of the underlying schematic page to a hierarchical block?
In large designs it would increase the "readability" significantly. Adding the information manually in plain text however can cause a big change-job as soon as a new page is added somewhere in the design and has the "potential to come out of sync"
Perhaps a Tcl-script could do the job?
  • swrimatt
    swrimatt over 5 years ago in reply to steve +1
    It looks like this has depreciated as I no longer see the Cadence TCL/Tk Utilities in the Accessories drop down. The %home%/cdssetup/OrCAD_Capture directory doesn't seem to have a tclscripts folder anymore…
  • briwei
    briwei over 4 years ago in reply to swrimatt +1
    You're an internet hero for posting an updated solution here. Thanks!
  • steve
    0 steve over 14 years ago
    There is an exisitng tcl script written by Cadence that may help. Open your Design then  Accessories - CadenceTcl/Tk Utilities - Utilities then under the Design Utilities is an Annotate H Block Page Number and launch.
  • Quist
    0 Quist over 14 years ago
    Thank you Steve for pointing that out!
    I'll have to check out what more goodies there are in the Tcl Dashboard.
  • Wild
    0 Wild over 11 years ago
    Decided to give this tcl utility a try.  Failed; I believe due to path length, my path has over 90 charterers.
    - Message: Annotation of Page Number H Block failed.
    So I saved the project in a temp directory - c:\TEMP
    The tcl now does not fail, but nothing happens when I click on the OK button.
    Release: Allegero Design Entry CIS 16.6 S055
    Suggestions?
    Many thanks.
  • Wild
    I was able to get this to work in the temp directory: solution closed the project and then ran the tcl script.
    I would appreciate if anyone has a solution for the longer path name.
  • swrimatt
    0 swrimatt over 5 years ago in reply to steve
    It looks like this has depreciated as I no longer see the Cadence TCL/Tk Utilities in the Accessories drop down. The %home%/cdssetup/OrCAD_Capture directory doesn't seem to have a tclscripts folder anymore.
    Has this moved somewhere else? I'm running OrCAD Capture CIS 17.4-2017 S018.
    Edit: I found the script in C:/Cadence/SPB_17.4/tools/capture/tclscripts/capAutoLoad/capAnnotateHBlockPageInit.tcl but i'm not sure how to run it.
    Edit2: I figured out how to get this to work.
    The link I posted above is just the initialization script run by Cadence on start up. You should see this in the Command Window when starting Capture.
    The instructions for how to run this particular script are found in the C:\Cadence\SPB_17.4\tools\capture\tclscripts\capAnnotateHBlockPage\tcl\capAnnotateHBlockPageNumber.tcl
    At the top of this file, they give you some instructions on how to run this script. Here's how that went for me:
    1. I closed my project that i want to annotate
    2. in the command window of cadence, i ran the following command:
    source {C:\Cadence\SPB_17.4\tools\capture\tclscripts\capAnnotateHBlockPage\tcl\capAnnotateHBlockPageNumber.tcl}
    3. This should put you on a newline that is blank. You are now "inside" the script where you can now run functions.
    4. in the command window, run the next command:
    capAnnotateHBlockPageNumber::AnnotateHBlockPageNumber {<full path to your .DSN file>}
    5. Open up your design and see the added references.
    It looks like the capAnnotateHBlockPageNumber.tcl has some additional details that can be modified if you wish to customize it further. But hopefully this should help anyone looking to get this to work.
    Edit3: So this script is working, but if I try/need to run it again, it causes many issues (changes my hierarchical block reference designators??). I suppose there's no real fix to this besides editing the script myself. Or saving a .DSN just before i add the annotation and use it as a backup in case i need to make any changes. Maybe if i get some time to go through the TCL script and correct this but i'm not great with TCL.
