  2. Allegro X Capture CIS
  3. Can't open BOM file with Excel
  • Replies 7
  • Subscribers 53
  • Views 11139
Hossein1357
Hossein1357 over 12 years ago
I am using OrCad 16.6 and I have a problem with it. When I try to generate BOM file one of important options is not active. As it is in below picture you see that I can't choose "Open in Excel" option.
I would appreciate any help,
Hossein
  • oldmouldy
    oldmouldy over 11 years ago +1
    Check out the past posts on this, you can either "View Output" and open the BOM in the application associated with the BOM file extension OR "Open in Excel", if you uncheck the "View Output" option the…
  • Hossein1357
    0 Hossein1357 over 11 years ago
    Yes, You are right. It was my mistake. I could do it.
    Thanks again,
    Hossein
  • ichliebedich
    0 ichliebedich over 6 years ago in reply to oldmouldy
    Thank you! I solved this problem
