  2. Allegro X Capture CIS
  3. Unable to copy and paste from one design to another in ...
  • Subscribers 54
  • Views 26466
Unable to copy and paste from one design to another in Capture
chads108
chads108 over 11 years ago
I have an engineer that is unable to copy and paste from one design to another in Capture.  He is getting the following error:
ERROR(ORCAP-1658): Unable to perform paste. Some objects on the clip board were not valid in this schematic.
I found the Source Link solution concern updating the cache and was able to get it fixed for him (It did take a while to narrow down the parts in error), but he still thinks something is broken because he has never run in to this before.    He says that the beauty of Capture is that it is not supposed to care about the symbols and it always would simply cut and paste and add new symbols to the design cache.  I am not a Capture guy, so I am wondering if maybe there is some switch that got thrown when we updated to 16.6 that is now making Capture check that the symbols are in sync across designs, or if something fundamentally changed in the last version or two.
Any insight from you Capture gurus?
  • oldmouldy
    0 oldmouldy over 11 years ago
    That would have been correct in the past, Capture didn't used to care about this at all and designs were regularly unstable as a result, the final cure for stability issues was to "just not allow" conflicting parts in the Design Cache, hence the need to correct them to be consistent.
  • chads108
    0 chads108 over 11 years ago
    Would that change have been in a fairly recent release?  The engineer is claiming the copy and paste "worked" in 16.3.
  • oldmouldy
    As I understand it, a number of solutions were tried to try to allow "any" Design Cache contents and maintain design stability through the 16.x releases but the outcome was to eventually "just not allow" conflicting parts in the Design Cache.
  • gyrogearloose
    0 gyrogearloose over 10 years ago
    I just bumped into this same issue.  It's very annoying when trying to maintain old schematics.
    A big part of the problem is that the verbiage in the error message is very poorly written.
    It would be a lot better if the error message suggested updating parts in the cache as a possible solution.
  • sencad
    0 sencad over 6 years ago
    Update cache in the source and destination schematics is the working (right) option, this way going forward the new SCH will be in better shape for upward mobility.
