  2. Allegro X Capture CIS
  3. Tools for netlist comparison?
  • Replies 9
  • Subscribers 51
  • Views 21106
pk359
pk359 over 11 years ago
Hi all,
As I make changes from one version of my schematic to the next, I like to verify the changes by comparing the before/after netlist. However, Orcad is not consistent in how it lists the components. For example:
*SIGNAL* 12V_DRIVE
LC5.1 U1.8 R6.1 R7.2 R5.2 TP6.1 C4.1
See how the components are not in alphanumeric order? Without changing the net, the order in the next version might be different. So when I do a difference comparison, it shows a difference when the net really hasn't changed.
So, is there a way to force Orcad to output the components in a netlist in order? Or is there a tool designed for netlist comparison?
Paul
  • steve
    0 steve over 11 years ago
    There are a few OrCAD Apps that will help with design compare between two OrCAD dsn files. Have a look at http://www.orcadmarketplace.com/OnlineStore.aspx some are free some are paid for. A good free one is http://www.orcadmarketplace.com/t60p-topic/ProductDetails/tabid/93/ProductID/45/Default.aspx
  • vignesh724452
    0 vignesh724452 over 6 years ago in reply to steve
    hi, the link mentioned by you isn't taking to the app, can you name the APP ??
  • steve
    0 steve over 6 years ago in reply to vignesh724452
    This post is over 6 years old! The OrCAD Apps are no longer available but this feature is built into the tools. From the Capture menu choose Tools - Compare Designs......
  • vignesh724452
    haha,
    thanks fr your quick reply...
  • vignesh724452
    hi steve,
    i don't find that option there...
    btw i'm using Orcad capture v16.6.112D
