  2. Allegro X Capture CIS
  3. Warnings while creating the NETLIST
  • Subscribers 53
  • Views 17383
AnirudhTHABJUL
AnirudhTHABJUL over 10 years ago
Hello everyone,
I am Anirudh THABJUL working as PCB designer in second-Bridge, Paris.
I am designing a schematic for my project in ORCAD CAPTURE CIS. while creating the NETLIST, I got following error
#1 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#14" as visible power pin of same name already exists in Package ATXMEGAxxxA3UG , U12A: 05- RANGING, RANGING (215.90, 63.50).
How to solve this warning?
Does it effects my routing on PCB layout?
Anirudh THABJUL
  • oldmouldy
    0 oldmouldy over 10 years ago
    It's just a warning. PCB Editor needs to have the pin names unique so the pins of type Power are being processed and, because "something" is being changed, you get a warning that the change has been made, just in case you want to handle the pin renaming rather than let the netlister take care of it. This isn't going to have any effect on the design.
  • AnirudhTHABJUL
    0 AnirudhTHABJUL over 10 years ago
    Thank you for your reply. I have found a way how to deal with above kind of warnings but i have got one more which is as follows
    #5 ERROR(SPMHNI-176): Device library error detected.
    ERROR(SPMHNI-189): Problems with the name of device 'CERAMIC_ANTENNA_0_WE7488930245_WE7488930245': 'Name is too long.'
    Do you know how to rectify this error?
    Anirudh THABJUL
  • Bamico
    0 Bamico over 8 years ago
    Have you solved this problem ?
  • riklee
    0 riklee over 8 years ago in reply to AnirudhTHABJUL
    The length of the name "CERAMIC_ANTENNA_0_WE7488930245_WE7488930245" is 44 characters. The default setting for the name length is 31
    You need to set the Long name size to > 44.
    If you are importing the files while in the PCB Editor set the value in the Design Parameters > Design tab
    If you are Capture creating the netlist and updating or creating a board file Select "Setup" in the Create Netlist dialog. In the Miscellaneous section of the Setup dialog set the Device/Net/Pin Name Char Limit to > 44
  • shavai
    0 shavai over 6 years ago
    Hi, Please let me know how did you solve this?
