  2. Allegro X Capture CIS
  3. How to update parts already placed from the Database
  • Subscribers 51
  • Views 21215
Joao Demier
Joao Demier over 10 years ago
I've been using Design Entry Cis 16.6 and I have an already finished big schematic with all components added from a Part Database (which is configured on the company's network).
All the components have a property which is the company's code.
The thing is, all the codes have been recently changed and I need to update the new values to the components placed on the schematic. Is there an easy way to do it? When I go to the Part Manager all the now changed component shows "Undefined", ever since I changed the companys code on the Database file. I do have a backup of the old database file (before the changes, all the parts were recognized there as from the database).
  • steve
    0 steve over 10 years ago
    In Part Manager try a Tools - Update All Part Status, Then click Yes and then Yes to All.
  • Joao Demier
    0 Joao Demier over 10 years ago
    Thanks for the answer, Steve.
    The problem is when I changed the company's codes on the database the parts already added to the schematic became "UNDEFINED" on the Part Manager, so I cannot update their part status.
  • steve
    In that case still use Part Manager, sort by a value (for example) then shift select parts that are the same and then choose right click - Link Database Part, the CIS Explorer window is opened with a filter of the value, select the part you want and choose right click Link and those parts are now assigned using the database ones. You may need to run Update all Part Status again to make them go Green and become Approved:Current.
  • Joao Demier
    Thank you, Steve. Now it's working.
  • BK2001
    0 BK2001 over 5 years ago in reply to steve
    Still works in 2021, thanks Steve!!!
