  2. Allegro X Capture CIS
  3. How to update design cache library paths and source library...
  • Subscribers 52
  • Views 20320
How to update design cache library paths and source library paths of all components in the schematic after upgrading orcad 17.0 to 17.2 lite?
iampaulq
iampaulq over 7 years ago
I have upgraded from 17.0 to 17.2 lite. But now, when I click on the properties of each component, they still point to the old library path as shown below:
It's the same with the design cache:
When I add a new component to the schematic using the design cache, it still works despite the error message that appears in the log:
I want to update all these paths to the new library path: C:\CADENCE\SPB_17.2\TOOLS\CAPTURE\LIBRARY\     from the old path C:\CADENCE\SPB_17.0\TOOLS\CAPTURE\LIBRARY\
  • Alok Tripathi
    0 Alok Tripathi over 7 years ago
    You can use Tools>Utilities>Replace path in Design cache to update olb paths in design cache. However you don't need to do this. You can continue to place parts from design cache or new olb locations.
  • iampaulq
    0 iampaulq over 7 years ago in reply to Alok Tripathi
    I tried replace path : old path= :\CADENCE\SPB_17.0\TOOLS\CAPTURE\LIBRARY\  then new path=C:\CADENCE\SPB_17.2\TOOLS\CAPTURE\LIBRARY\  I then clicked check just to make sure I won't break anything and it gave an error message: ERROR(ORCAP-45014): Replace path in design cache is failed. Design cache already contains packages which refer to the new path.
    INFO(ORCAP-45016): Number of element passed= 0 and failed= 0. ………..Yes, I simulated my schematic and it still works, despite the wrong source library. How does it know the properties of the parts if the library path is wrong, is everything stored in the design cache? What if I accidentally cleared the cache?
  • V kumar
    0 V kumar over 5 years ago
    i am also facing same issue please help me
  • V kumar
