  2. Allegro X Capture CIS
  3. OrCAD Capture Part reference
  • Subscribers 51
  • Views 19952
jatins
jatins over 7 years ago
Hi
I am working on a hierarchical Schematics and almost done with it. Before transferring it to board layout, i have to add some small parts here and there on the schematics. The issue i am experiencing is that whenever i try to place a part (Example:resistor) on Page 5, the part reference number which is allotted to it is (Example : R56). This part reference is already present on Page 6 such that now i have 2 resistors on the schematics with the same part number. Earlier i used to run "Reset Part references to ?" and then "Incremental reference update" which solved this issue.
But what i want is that Capture should automatically increment the part reference whenever a new part is placed so that there are no conflicts between part references.
  • oldmouldy
    oldmouldy over 7 years ago +2
    Under Options>Preferences, Miscellaneous tab, in Auto Reference, check the Automatically Reference Placed Parts and the Design Level options.
  • jatins
    jatins over 6 years ago in reply to oldmouldy +1
    Hi again Just found out that when i have checked the above mentioned checkboxes, only the connectors are working according to this option. i.e. the new connectors i am using in Schematics are having…
  • oldmouldy
    0 oldmouldy over 7 years ago
    • Vote Up +2 Vote Down
  • jatins
    0 jatins over 7 years ago in reply to oldmouldy
    Thanks.... it helped :)
  • jatins
    0 jatins over 6 years ago in reply to oldmouldy
    Hi again
    Just found out that when i have checked the above mentioned checkboxes, only the connectors are working according to this option. i.e. the new connectors i am using in Schematics are having different part references than the ones already present in Schematics.
    But almost everything else does not follow this rule.i.e.Resistors, Capacitors, ICs all start with R1, C1, and so on.
