  2. Allegro X Capture CIS
  3. Export to PDF no longer working in Capture CIS 17.2
  • Subscribers 52
  • Views 15864
rsbonini
rsbonini over 6 years ago
When I try to export to PDF from Capture CIS, the session log shows "(::capPdfUtil::printPdf) Generating PDF file from postscript ...." but no file is ever generated.  This function was working yesterday when I shutdown.  I've tried changing the Postscript Driver from "Microsoft Print to PDF" to "OrCADPS_17.2" after creating a generic printer with that name but no luck.
Without even an error message I'm not sure what the issue is.  Any suggestions would be appreciated.
  • MDiPenta
    MDiPenta over 6 years ago +1
    Same here -- tried with 64 and 32 bit versions of GS (Win 10).
  • MDiPenta
    0 MDiPenta over 6 years ago
  • AvengerThanos
    0 AvengerThanos over 6 years ago
    The PDF export works fine in CIS too. Browse the path again for Ghostscript (if you are using GS as a converter) or the Acrobat distiller. Save the design once before exporting to PDF. I am using 17.2 S0064 and found no issue in exporting PDF
