  2. Allegro X Capture CIS
  3. Unable to update the PCB board file using updated schematic...
  • Subscribers 52
  • Views 15352
Ramelb
Ramelb over 6 years ago
Good day Engineers,
Hello Sir/ Ma'am,
I'm new into cadence and I'm having difficulties to debug the problem using Allegro PCB Design Entry HDL.
Firstly, I'm using Cadence 17.2 version. I have updated schematic file but when I try to export my ( Input BOARD Files - not updated board ) into my new ( Output Board file - Updated schematic w/ New components added) I'm having errors, these are the error
------ Oversights/Warnings/Errors ------
Start Constraint Diff3 Import
Constraint File: C:/Users/JM/Downloads/15mh/feb27/worklib/ltc/packaged/pstcmdb.dat
Allegro Baseline: C:/Users/JM/AppData/Local/Temp/#Taaaaae74660.tmp
Start time: Thu Feb 27 12:18:27 2020
ERROR: Schematic database has probably been reverted to an earlier version than that, which was used in the latest flow.
The basecopy file generated by the last back-to-front flow not found.
ERROR: Schematic supports automatically creating XNets using DML but the Layout will not automatically create any XNets. Change setting in Layout or Schematic, re-generate files, and re-run the flow.
ERROR: Can't import electrical constraint data (pstcmdb.dat)
Finished Constraint Update Time: Thu Feb 27 12:18:27 2020
Much Appreciate.
John
  • CC24
    0 CC24 over 6 years ago
    Hi John
    I just got the same error message. Did you find a solution?
    Claudia
  • steve
    0 steve over 6 years ago in reply to CC24
    Take a look at this support.cadence.com/.../ArticleAttachmentPortal
