  2. Allegro X Capture CIS
  3. Issue during netlisting-Error(ORNET-1193)
  • Subscribers 51
  • Views 9834
KeithM657
KeithM657 over 6 years ago
Hi, I am struggling to get a netlist generated. I had to update a schematic that was originally done in an older version. This meant updating issues with footprint names such as removing dashes, dots etc. Got this done, Made sure the footprints could be found but I keep getting the error in the title and the commands below are generated. It says that the details for the errors can be found in the netlist.log files but this is empty when I go check there.
Anyone have any ideas?
I am on the following software versions:
17.2 S062
Spawning... "C:\Cadence\SPB_17.2\tools\bin\pstswp.exe" -pst -d "C:\USERS\10126903\ONEDRIVE - B\Ng\Ng-REDESIGN\Ng MAIN SCHEMATIC_KM25_MAR_20.DSN" -n "C:\Users\10126903\OneDrive - B\Ng\Ng-Redesign\Netlist" -c "C:\Cadence\SPB_17.2\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
Exiting... "C:\Cadence\SPB_17.2\tools\bin\pstswp.exe" -pst -d "C:\USERS\10126903\ONEDRIVE - B\Ng\Ng-REDESIGN\Ng MAIN SCHEMATIC_KM25_MAR_20.DSN" -n "C:\Users\10126903\OneDrive - B\Ng\Ng-Redesign\Netlist" -c "C:\Cadence\SPB_17.2\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
INFO(ORNET-1179): *** Done ***
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    Under project hierarchy - outputs - you can find pstswp.dat, pstchip.dat, pstxnet.dat delete all the 3 and then save design. then Netlist I think this should help you solve the issue. Also, make sure you…
  • KeithM657
    KeithM657 over 6 years ago in reply to AvengerThanos +1
    There were no outputs there in that output folder. But I did manage to get it fixed. There was an issue with a bus on one of the pages. When it was deleted and I used net alias I managed to get it netlisting…
  • AvengerThanos
    0 AvengerThanos over 6 years ago
    Under project hierarchy - outputs - you can find pstswp.dat, pstchip.dat, pstxnet.dat delete all the 3 and then save design. then Netlist I think this should help you solve the issue. Also, make sure you have given the .psm and .pad path correctly
  • KeithM657
    0 KeithM657 over 6 years ago in reply to AvengerThanos
    There were no outputs there in that output folder. But I did manage to get it fixed. There was an issue with a bus on one of the pages. When it was deleted and I used net alias I managed to get it netlisting. Thanks for the help.
