  2. Allegro X Capture CIS
  3. orcad capture 17.2: Bus has no name and therefore defines...
  • Subscribers 51
  • Views 16696
orcad capture 17.2: Bus has no name and therefore defines no signals
frank mpbc
frank mpbc over 6 years ago
I was doing a DRC and got "Bus has no name and therefore defines no signals". How do I fix that?
I put a bus with bus entries on the bus and wires with net aliases SCL0 and SDA0.  If I double click on the bus it shows Net Properties with Name N149...  What's wrong, how do I fix?
Frank
  • steve
    steve over 6 years ago +1
    So buses must have the same netname type A0 - A7, DQ0 - DQ7, MSB...LSB based on the same name, and the BUS must have the same name A[0-7]. DQ[0-7]. If you want to use different netnames then create a Netgroup…
  • steve
    0 steve over 6 years ago
    So buses must have the same netname type A0 - A7, DQ0 - DQ7, MSB...LSB based on the same name, and the BUS must have the same name A[0-7]. DQ[0-7]. If you want to use different netnames then create a Netgroup. There's a video on netgroups www.youtube.com/watch
  • frank mpbc
    0 frank mpbc over 6 years ago
    Thanks Steve. That solved it.
    Frank
