  2. Allegro X Capture CIS
  3. NetList output reference designator string length with orWireList...
  • Subscribers 51
  • Views 13189
NetList output reference designator string length with orWireList.dll
RenoMike
RenoMike over 6 years ago
It appears that there is a maximum number of characters (9) for component reference designators when generating a netlist using the orWireList.dll option (on the "other" tab).  Does anyone know if there is any way to increase the maximum number of characters allowed for that field?
  • masamasa
    0 masamasa over 6 years ago
    you can set the max length of the reference designators by typing in the command line:
    set REF_DES_LENGTH 255
  • RenoMike
    0 RenoMike over 6 years ago in reply to masamasa
    Thank you masamasa, I gave that a try and net list output is still the same.  Reading through the netlist help documentation it appears to be a limitation of that particular netlist output option.  Would be nice to find a way to increase that limitation since we've written some custom tools around the output.
