  2. Allegro X Capture CIS
  3. capture update cache vs replace cache
  • Subscribers 51
  • Views 18376
frank mpbc
frank mpbc over 6 years ago
In Capture 17.2, I changed in the library part X. I like to push the change library -> schematic.
In the design tree at design cache for part X, I right click and see update cache and replace cache.
What are the differences?
Do they all go in the direction library -> schematic?
Frank
  • oldmouldy
    oldmouldy over 6 years ago in reply to frank mpbc +1
    Replace Cache allows another OLB file / Part to be selected as the "replacement" part, Update Cache only "updates" the part with the original library part name from the original library path.
  • oldmouldy
    0 oldmouldy over 6 years ago
    Fundamentally, Update Cache uses the "library path" in the Design Cache, Replace Cache allows "any" part and part to be selected.
  • frank mpbc
    0 frank mpbc over 6 years ago in reply to oldmouldy
    Thanks for your response. I think I get what you are saying for update cache.  I am still a bit unclear on the replace cache.
    Frank
  • oldmouldy
    0 oldmouldy over 6 years ago in reply to frank mpbc
  • frank mpbc
    Thanks for your help.
    Frank
