  2. Allegro X Capture CIS
  3. Capture schematic fastest way to FIND PART
  • Replies 7
  • Subscribers 51
  • Views 21164
frank mpbc
frank mpbc over 6 years ago
I currently use Edit-> browse parts to find parts. I leave that tab open.
Is there another faster way to engage a find function and just type in the part reference?
Frank
  • steve
    0 steve over 6 years ago in reply to frank mpbc
    So your env file is ONLY for PCB editor, this has nothing to do with OrCAD Capture, The Find command is different in 17.2 v 17.4.. By default select the design name in the project window and this will become active
    You can type your refdes in this window and hit return. The Binoculars and arrow can help with what you are searching for. If you don;t like this go to Options - Preferences - Miscellaneous tab and uncheck Find Search Toolbar then use Edit - Find and you'll see a window like this
  • frank mpbc
    0 frank mpbc over 6 years ago in reply to steve
    It is working the way you described! Thanks!!!
    Frank
