  2. Allegro X Capture CIS
  3. Capture schematic fastest way to FIND PART
  • Replies 7
  • Subscribers 51
  • Views 21163
frank mpbc
frank mpbc over 6 years ago
I currently use Edit-> browse parts to find parts. I leave that tab open.
Is there another faster way to engage a find function and just type in the part reference?
Frank
  • steve
    0 steve over 6 years ago
    Yes - there is an Edit - Find command....
  • frank mpbc
    0 frank mpbc over 6 years ago in reply to steve
    I have my schematic open. I click Edit , Find  and nothing happens. When I do Ctrl F, nothing happens either. I tried several other commands in the Edit menu and they seem to work.
    Frank
  • steve
    0 steve over 6 years ago in reply to frank mpbc
    So what version are you using? I have 17.4-2019 S007 and when i do that I get the Find window appear on the right hand side of the Capture window.
  • frank mpbc
    I have orcad capture CIS version 17.2-2016
    I have a  Ctrl F hotkey in my c:\spb_data\pcbenv\env for usage in Allegro. Should that override the Capture Ctrl F?
    source $TELENV
    ### User Preferences section
    ### This section is computer generated.
    ### Please do not modify to the end of the file.
    ### Place your hand edits above this section.
    set padpath = $padpath C:/docs_frank/orcad_lib_local/
    set psmpath = $psmpath C:/docs_frank/orcad_lib_local/
    set steppath = $steppath C:/docs_frank/orcad_lib_local/
    set viewpath = "C:/docs_frank/orcad_lib_local/color views"
    unset no_etch_shape_display
    unset no_shape_fill
    ### Frank added: `funkey r iangle 45`
    ### www.youtube.com/watch
    funkey r iangle 90
    ###www.parallel-systems.co.uk/.../PCB_Editor_customization.pdf
    funckey d "delete; pick_to_grid -cursor; done" # delete using the d key.
    funckey m "pop mirror" # mirrors symbol during place manual
    ## CTRL F find component symbol
    alias ~F "prepopup ; pop dyn_option_select 'Selection set@:@Clear all selections';set prompt;prompt 'Find Ref Des';refdes $prompt;zoom selection"
    ## CTRL N find net
    alias ~N "prepopup ; pop dyn_option_select 'Selection set@:@Clear all selections';set prompt;prompt 'Find Net Name';net $prompt;zoom selection"
  • frank mpbc
    0 frank mpbc over 6 years ago in reply to frank mpbc
    I commented out the Ctrl F in the env file. The Find still does not work in the Capture. Now, the Ctrl F I added for Allegro does not do anything anymore.
    Frank
