  2. Allegro X Capture CIS
  3. Export PDF from Capture. 17.4 Hotfix11
  • Subscribers 51
  • Views 18407
JuriV
JuriV over 6 years ago
I tried to generate PDF from Capture by File--> Export--> PDF. I used Acrobat Distiller 11. Three files are in the directory: CapMark, CapOutput and CapPropMark. These files are PostScript. If I open e.g. CapOutput the pdf with schematic will be generated, the file CapMark generates components. How is it possible to generate the complete intelegence pdf. file for the Project?
  • RFinley
    0 RFinley over 6 years ago
    From my understanding, the PDF process deletes the postscript files after Acrobat successfully distills them to a PDF.   So, the process isn't finishing.
    What do you show in the bottom half of the PDF export dialog?
    What is shown for "Driver"
    Do you see the "acrodist.exe is available" green message at the bottom (CIS was able to find the distiller exe file.)?
