  2. Allegro X Capture CIS
  3. Export PDF from Capture. 17.4 Hotfix11
  • Subscribers 51
  • Views 18406
JuriV
JuriV over 6 years ago
I tried to generate PDF from Capture by File--> Export--> PDF. I used Acrobat Distiller 11. Three files are in the directory: CapMark, CapOutput and CapPropMark. These files are PostScript. If I open e.g. CapOutput the pdf with schematic will be generated, the file CapMark generates components. How is it possible to generate the complete intelegence pdf. file for the Project?
  • RFinley
    0 RFinley over 6 years ago
    When you do a >File >Export >PDF, does the dialog box look like this?
  • JuriV
    0 JuriV over 6 years ago in reply to RFinley
    Yes, by OK Click the post scrip files CapMark, CapOutput and CapPropMark will be generated. But not pdf. These files generates pdf, but not intelegence one. One pdf is only schematic, second is the list of compoenents.
  • AvengerThanos
    0 AvengerThanos over 6 years ago in reply to JuriV
    Browse the path of the distiller again and close the window. Save the design then select .dsn and file - export - PDF. I think this should help you get an intelligent PDF.
  • JuriV
    0 JuriV over 6 years ago in reply to AvengerThanos
    No, doesn't work
  • JuriV
    0 JuriV over 6 years ago in reply to JuriV
    And I have Hotfix 11
