  2. Allegro X Capture CIS
  3. Microsoft Office 2019 "Click2Run" No ODBC-Drivers for Access...
  • Replies 7
  • Subscribers 51
  • Views 9882
Microsoft Office 2019 "Click2Run" No ODBC-Drivers for Access .MDB-files - Advice how to move forward?
UlfK
UlfK over 5 years ago
Having installed  Office 2019 after a computer upgrade I discovered that I could not configure an ODBC 64 bit data source for our Access .MDB database used for CaptureCIS. After some searching, the answer was that Microsoft does not provide the possibility to add ODBC drivers for .MDB in an Office 2019 Installation "Click to Run". The only possible drivers are in principle "SQLite 3". Previously, I had to overcome the problem with ODBC configuration on SAMBA mapped drives that Microsoft did not allow using its GUI. The mapping had to be defined in the Registry editor. All was well until I hit this one today... An easy way would be to convert to Excel but there is no driver for that format either.
Since Access can export to SQL-format (at least according to the export menus) I think that the only possible way forward is in that direction.
But can the Cadence software 17.2 and 17.4 connect the CIS to such databases?
Is there any easy enough front end for SQLite 3 that does not require a lot of hardware and software resources?
Comments invited.
  • steve
    steve over 5 years ago +1
    Give this a try: Datasources for OrCAD Capture CIS 17.x (64-bit) (parallel-systems.co.uk) and if this doesn't work try Migrating Microsoft Access DB to Microsoft SQL Server (parallel-systems.co.uk)
  • steve
    steve over 5 years ago in reply to UlfK +1
    So as RFinley has said OrCAD CIP does this for you and is a solution out of the box. Might be worth a chat to your channel partner to discuss this. Watch this OrCAD Capture CIS CIP Component Information…
  • steve
    0 steve over 5 years ago
  • UlfK
    0 UlfK over 5 years ago in reply to steve
    Parallel System Excels ... again ... by providing very useful information!
    The next question is to find a suitable SQL "Front End" that allows for editing/adding entries to the SQL database.  I have found some suggestions on the internet. Will continue  searching.
  • RFinley
    0 RFinley over 5 years ago in reply to UlfK
    It's hard to beat the power and simplicity behind Postgres SQL (preferred DB for Atlassian).
    But, Microsoft also gives away their excellent MS-SQL Express Edition up until you reach a really huge data set size (10Gb).  Then they have you pay for it.
    MS-SQL is also the foundation for the excellent EMA-EDA CIP component management system.  A CIS db that imports part data directly from distributors, tracks BOMs and where-used, and has the option to sync with Silicon Expert for obsolescence tracking.  SQL server express does not have the "smart Backups) found in Web and higher.
  • UlfK
    0 UlfK over 5 years ago in reply to RFinley
    "We" are an academic institution and the size of our little database is only a few MBytes. The last time I did database work was with "dBase IV" back in 1989. (I am that old.) SQL is completely unchartered territory. I have found some books like "SQL for dummies" which probably is 100% me. However, I am not into programming at all and that is why I once chosed Access with .MDB-file format. It was easy and we were in a hurry.
    Thank you both for valuable hints. I will continue to search for information.
  • steve
    0 steve over 5 years ago in reply to UlfK
    So as RFinley has said OrCAD CIP does this for you and is a solution out of the box. Might be worth a chat to your channel partner to discuss this. Watch this OrCAD Capture CIS CIP Component Information Portal - YouTube which should give you a brief overview. You should be able to link MS access to an ODBC data source though so you can use Access as the interface. Once you have the SQL database go to Access and create a new DB then go to External Data - New datasource - From Other sources - ODBC and choose your new SQL datasource. Thus will only allow to add new entries to the DB, not change / add fields etc.
