  2. Allegro X Capture CIS
  3. Netlisting from Capture to PCB Editor Changes Differential...
  • Subscribers 51
  • Views 12321
Netlisting from Capture to PCB Editor Changes Differential Pairs in PCB Editor
Gipper
Gipper over 5 years ago
My toolset is OrCAD PCB Designer Professional 17.4 S011.
I am having an issue where when I import a netlist into PCB Editor from Capture, it changes a few of the differential pairs that I have configured in the Constraint Manager. For some of the differential pairs it renames them, and for others it completely removes the differential pair. Each time I make an adjustment to the schematic then netlist, I have to go back to constraint manager to re-configure these differential pairs.
Is there any setting or adjustment that I can make that will not permit the Capture netlist to adjust my differential pairs in PCB Editor after importing the netlist?
  • Wild
    Wild over 5 years ago +1
    Note: This is shown in 16.6 not sure if it works this way in later versions: When creating a netlist and I don't want the pcb constraints over written I use the nestlist - Ignore Electrical constraints…
  • Gipper
    Gipper over 5 years ago in reply to Wild +1
    Yes! Thank you. That worked.
  • Wild
    0 Wild over 5 years ago
    When creating a netlist and I don't want the pcb constraints over written I use the nestlist - Ignore Electrical constraints option.
  • Gipper
    0 Gipper over 5 years ago in reply to Wild
