  2. Allegro X Capture CIS
  3. Import user defined property from Capture schematic to PCB...
  • Subscribers 51
  • Views 11176
Import user defined property from Capture schematic to PCB-Editor Layout
Davide98
Davide98 over 5 years ago
Hey all,
I have defined in my schematic symbols the component mounting style as a user-defined property; I'd like to import it to PCB-Editor to be able to faster create the pick and place report without having to create two different files reports (one with the component coordinate and the other with the list of all the pad hole, if it has a hole it is TH) and then work them into excel.
Thank you!
  • steve
    0 steve over 5 years ago
    Look at PCB - Design Sync Setup and enable Create User Defined Properties. You will also need to go to Tools - Create Netlist, Setup button and edit the allegro.cfg file to add the property name. usually in ComponentDefinitionProps section the property name = Yes So MyProperty=YES. save the file and this is then transferred to PCB editor via the netlist.
  • Davide98
    0 Davide98 over 5 years ago in reply to steve
    It works perfectly, thank you
