  2. Allegro X Capture CIS
  3. OrCAD Capture hierarchical block import / export
  • Subscribers 51
  • Views 11975
ichliebedich
ichliebedich over 5 years ago
Hi all
if we suppose seperating 2 teams as A and B
if A team create a number of hierarchical block schematics, then export that data to send B team.
and B team import the hierechical schematic for integrate main schematic.
is it avaliable in OrCAD Capture? if right, how can I do that? if you have some usuful links or sheet, please let me know.
I tried to export schematic using for hierechical block with XML format, but there was no any XML import function at creating hierechical block
so I tried to import .dsn file, but not work properly
regard
  • RFinley
    0 RFinley over 5 years ago
    I suspect the answer to your question is on http://support.cadence.com,  a Rapid Adoption Kit named "Reuse Flow in Allegro Design Entry CIS."  I think this works the same in Orcad CIS.
    There is the PDF walkthrough plus an attachment of example CAD files for you to start playing with.
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to RFinley
    Thank you ! it was useful!
