  2. Allegro X Capture CIS
  3. OrCAD Capture - Edit net aliases
  • Subscribers 51
  • Views 5419
Fredda
Fredda over 5 years ago
How do I list and edit net aliases? I get a lot of DRC errors like:
Warning(ORCAP-1589)
WARNING(ORCAP-1589): Net has two or more aliases that might lead to a short. Ensure nets are not shorted together or nets do not have two or more aliases. This message is displayed because 'Report all net names' is set in Design Rules Check dialog.
U1,VS VS 24V
U1 is not even part of the design anymore since the component has been removed.
And can I stop OrCAD from using the pin name on a component to name a net?
/F
  • AvengerThanos
    0 AvengerThanos over 5 years ago
    Annotate your design and delete existing wiring connection and redraw the wire and provide net name. This helps.
  • Fredda
    0 Fredda over 5 years ago
    The design is already annotated and I don't want to reannotate it since that will probably break the layout.
    And deleting exisitng connections and redrawing the wires is not an option since I have close to 100 similar warnings.
