  2. Allegro X Capture CIS
  3. Migrating designs from OrCAD capture 17.2 to OrCAD capture...
  • Subscribers 52
  • Views 13443
Migrating designs from OrCAD capture 17.2 to OrCAD capture CIS 17.4.
KramYesoh
KramYesoh over 5 years ago
I want to migrate a number of designs from OrCAD capture 17.2 to OrCAD capture CIS 17.4.
Not too difficult. But my main aim is to replace all of the schematic components defined in local libraries with those that I’m creating in the CIS database.
My question might be a bit naïve but how do I go about doing that? I can't find anything in the user manual about it or any online tutorials or articles on the subject.
Is there a quick and efficient way to replace components, placed in the 17.2 schematic which has been loaded into 17.4 capture with CIS, with components in the CIS data base or is it a case of going through the migrated schematic component by component, deleting and replacing?
Oh what fun…….
Any help for a novice gratefully accepted.
Mark
  • oldmouldy
    0 oldmouldy over 5 years ago
    It may depend on exactly what you want to do but, typically, the only requirement is Link the existing parts in the Schematic to the equivalent Parts in the CIS Database, basically adding the Part Number property from the Database. You can do this efficiently through the Part Manager, right-click on the DSN file entry in Project Manager, for instance, left-click the Value column to sort by Value, then you can left-click on the first entry for a Value and shift+left-click on the last entry for the Value and right-click>Link Database Part to open the CIS Explorer with a list of possible parts for the selected value, and select a Part and Link Database Part from there. In this way you can "bulk" link a number of Parts, rather than linking each Part individually. If you really want to replace the library paths used, not strictly necessary, you will need to open the Design Cache and start using Replace Cache on the Parts in the Design Cache but this probably isn't going to get you a great benefit for the effort expended.
  • KramYesoh
    0 KramYesoh over 5 years ago in reply to oldmouldy
    Fabulous!
    Thankyou very much Oldmouldy.
  • lthomson
    0 lthomson over 5 years ago
    This seems to be the consensus on how to update the library paths in the design cache, however, this only appears to work at best for around half the parts. The remainder I'm forced to update the design cache paths one at a time. Is there a fix for this or another way to to do a batch update?
