  2. Allegro X Capture CIS
  3. Bug
  • Subscribers 52
  • Views 9724
Bug
Saagar Chhetri
Saagar Chhetri over 5 years ago
The schematic below was working fine, but when I moved the transformer text I am getting errors. The errors aren't descriptive enough to take any appropriate actions.
Any help will be massively appreciated, I am on the verge of leaving Electrical Engineering because of stuff like this.
  • oldmouldy
    oldmouldy over 5 years ago +1
    Anything is possible but I doubt that just moving text in the Schematic is at the root of the problem. Check out this note on the Cadence Support site: https://support.cadence.com/apex/ArticleAttachmentPortal…
  • oldmouldy
    0 oldmouldy over 5 years ago
    Anything is possible but I doubt that just moving text in the Schematic is at the root of the problem. Check out this note on the Cadence Support site: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nUqjEAE&pageName=ArticleContent
  • Saagar Chhetri
    0 Saagar Chhetri over 5 years ago in reply to oldmouldy
    Great! thank you very much it worked, I checked all of the possible errors listed in the site, none of them matched, not sure what's going on.
  • oldmouldy
    0 oldmouldy over 5 years ago in reply to Saagar Chhetri
    It looks like you may have both MOSFETS conducting at the same time, also, from the messages, the screen shot doesn't look like the entire circuit. You can use File>Archive Project with the DSN file entry selected in the Project Manager to create a single file archive of the project if you want any further investigation, add any custom models that aren't in the installation to the archive before uploading.
