  2. Allegro X Capture CIS
  3. OrCAD Capture bi-direction Off-page symbol
  • Subscribers 52
  • Views 16216
ichliebedich
ichliebedich over 5 years ago
Hi All
As I know there are 2 off-page symbol IN/OUT
but I am looking for bi-directional off-page symbol..
How can I use for bi-directional off-page symbol? Doesn't OrCAD support this?
regard
  • oldmouldy
    0 oldmouldy over 5 years ago
    An Off-Page Connector just makes the Net, or Bus / Net Group, "public" to other Pages at the same level in the design, if flat, or hierarchy, for a hierarchical design, there isn't any Type property associated with the Off-Page Connector and any "direction" is purely graphical. If you need to use some different graphics, you can add you own Off-Page Connectors, with associated graphics, to your own libraries.
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to oldmouldy
    Thank you, so I tried to make own off-page connector, but there is no any edit menu if I RMB of any off-page connector
  • oldmouldy
    0 oldmouldy over 5 years ago in reply to ichliebedich
    You need to open, or create, the "target" Library, then either Design>New Symbol, or select the OLB file entry in the Project Manager pane and right-click>New Symbol, then you get to pick the Symbol type that you want to create, in this case, Off-Page Connector.
  • TEDH4DDV
    0 TEDH4DDV over 2 years ago in reply to oldmouldy
    This was a misguided decision by Cadence.  Much of a schematic is 'purely graphical'.  Why place pin names on symbols except to make the schematic readable?  The appearance of the symbol cues the person reading the schematic about the nature of the signal flow, be it input, output or bidirectional.
