  2. Allegro X Capture CIS
  3. Empty Bill of Materials
  • Replies 7
  • Subscribers 53
  • Views 12531
jatins
jatins over 4 years ago
Hi
Started experiencing this problem recently regarding BOM being completely empty when i run Reports> CIS BOM> Standard.
My settings are:
  • jatins
    0 jatins over 4 years ago in reply to Zhifeng Jin
    We got somewhat more closer to the goal. I had checked 'keyed' for all the options in the output format. Probably did this change last time to make it work.
    But still the remaining problem is 'default' option in 'Variants' does not output any data. Don't remember longer if 'Variant"Not Stuffed" Qty 0 Displayed' needs to be checked. I have it as unchecked now.
    And why capture is still showing S024 Hotfix installed and not S025.
  • Zhifeng Jin
    0 Zhifeng Jin over 4 years ago in reply to jatins
    S024 is still displayed after installing s025hotfix. I also have this problem. This should be the problem of hotfix itself. At least the version displayed on the windows registry and program uninstallation is correct, so I don't care
