  2. Allegro X Capture CIS
  3. Empty Bill of Materials
  • Replies 7
  • Subscribers 53
  • Views 12530
jatins
jatins over 4 years ago
Hi
Started experiencing this problem recently regarding BOM being completely empty when i run Reports> CIS BOM> Standard.
My settings are:
  • Alan K
    0 Alan K over 4 years ago
    This seems to have occurred with Hotfix 023.
    I have opened a case with Cadence.
    I don't know how quickly the fix can get incorporated in the next hotfix.
    Alan
  • jatins
    0 jatins over 4 years ago in reply to Alan K
    Yes. Ran BOM export in another PC with Hotfix 022 and no problem there.
    Not sure, may be this below issue is also related to the same 023 hotfix i posted a while ago:
    plated-mounting-hole-covered-by-soldermask
    I could have tried making another Board file out of my design as Steve suggested in that thread, but it was taking long time to do it.
  • Zhifeng Jin
    0 Zhifeng Jin over 4 years ago
    Hi jatins, you can shorten the length of the DSN file name, such as less than 9 characters, and then export the BOM. Try it and you will find a surprise.
  • jatins
    0 jatins over 4 years ago in reply to Zhifeng Jin
    Hi Tried with less than 9 characters in the .dsn file name. It works partly and not 100 percent.
    The report outputs like 'Standard-Separate line per part' option even though i have selected 'Standard' option in the BOM Window.
     So, i am not getting output report where the same Part number components are gathered in a single row.
    Also, i think the 'Default' variant option where Do not mount components are not output in the excel file does not work at all.
    One more thing: Even though i installed Hotfix S025 on my PC and Download Manager is confirming 17.40.025 Hotfix. But Capture is still showing S024.
  • Zhifeng Jin
    0 Zhifeng Jin over 4 years ago in reply to jatins
    In the Output option, select the Part Number and then check Keyed. The exported table will automatically place components with the same Part Number on the same row. Smile
