  2. Allegro X Capture CIS
  3. Component location export to BoM
  • Replies 7
  • Subscribers 51
  • Views 13080
RSYED
RSYED over 4 years ago
I'm using Capture 17.4 and in the past I would be able to backannotate/sync to pull in component side/location information (i.e. top or bottom) from layout to capture.
I could subsequently export that information to my BOM. Does anyone have any insight on how to do this in 17.4?
Thanks!
  • DS1995
    DS1995 over 4 years ago in reply to RSYED +1
    Any property was transferred from Allegro PCB editor into capture through the Backannotation process. In Capture 17.4 this can be done through the menu command PCB > Update Schematic. You can control…
  • RSYED
    0 RSYED over 4 years ago in reply to AyushD
    Where should that be nested with in the CFG? Component definition or component instance?
  • RSYED
    0 RSYED over 4 years ago in reply to RSYED
    It was in instance
    Thank you for your help!
