  2. Allegro X Capture CIS
  3. OrCAD Capture: Advance Annotation function
  • State Verified Answer
  • Replies 7
  • Subscribers 52
  • Views 14897
yywhy
yywhy over 4 years ago
Hello forum,
Anyone knows how do I activate the advance annotation function?
Please help
  • DS1995
    DS1995 over 4 years ago +1 verified
    It seems like you are trying to do advanced annotation on a Pspice schematic project type. Advanced annotation will only appear in this dialogue box for PCB schematic design. Select File > New > Schematic…
  • DS1995
    DS1995 over 4 years ago in reply to mdabdi +1
    Hi, If you do not want to create a combined netlist of all the folders, then that means these folders have no relation with each other from the design/Board perspective. (As per my understanding - that…
  • DS1995
    0 DS1995 over 4 years ago in reply to mdabdi
    If you do not want to create a combined netlist of all the folders, then that means these folders have no relation with each other from the design/Board perspective. (As per my understanding - that is why you are not calling folders like S1-S7 in MB root schematic).
    If you still feel the need to keep these folders in the same project (and create netlist separately for each folder), then I suggest the following -
    Create netlist for with MB as ROOT > Once, this is done, RMB on S1 in project manager and select "Make Root".
     Now create netlist with S1 as root. (Similarly do it from S2 to S7).Hence, creating 8 different Netlists and Boards. However, a better solution would be to create 8 different projects for 8 folders (as they seem to be not related).
    In case the term "sub-boards" was meant to refer the ability to reuse a pre-designed schematic in new schematic and Board, then please refer to - https://community.cadence.com/cadence_technology_forums/pcb-design/f/capture-cis/50801/redrawing-a-circuit-is-a-thing-of-past
    Good LuckThumbsup
  • mdabdi
    0 mdabdi over 4 years ago in reply to DS1995
    Noted with thanks.
    I have tried your method but annotation was an issue because I was not able to annotate properly there were issues relating to Update Occurrences and Instances.
    I decided to create 8 different project to cater for the proper annotation and also the creation of netlist. This method works as per wanted.
