  2. Allegro X Capture CIS
  3. How to add a custom page size to the Smart PDF printer
  • Subscribers 50
  • Views 10336
LEMH
LEMH over 4 years ago
Hi guys,
   Does any body knows how can I add a custom page size to the Smart PDF printer?? (no Microsoft PDF Printer, Distiller, Ghostscript or any other plain PDF printer, I already know the workaround there).
The thing is I need to print a smart pdf with a custom page size, but I don't know how to add a custom page size to the Smart PDF printer.
I've tried to add the custom page size and put it on the list that is inside the capPdfUtil.tcl file, but even if the custom page is added to the list, when I print the smart PDF, it just simply ignore the size I've added
and it prints the schematic in a different size. So I think is not just enough to add the custom page size to the list on the 'mPaperSizeList' located inside the capPdfUtil.tcl.
Thanks.
Regards.
  • LEMH
    0 LEMH over 4 years ago
    nevermind, I find out, if someone ever seen this msg.... the easiest way is to buy a pdf reader cable to process postscript, the cheaper way is a little bit longer to explain it here, since involves so many steps and cares, if you ever need this just ping me...
    Saludos compadres !!!
  • printerdriver
    0 printerdriver over 1 year ago
    Hey,
    Yeah, ran into the same issue a while back. Just editing `capPdfUtil.tcl` isn't enough the Smart PDF printer seems to only support predefined paper sizes hardcoded somewhere deeper (maybe compiled). I never found a way to fully force a custom size through that list.
    Ended up using a workaround where I scaled the schematic to fit a supported size — not ideal, but it worked.
    Would love to know if someone’s cracked it properly though.
    Cheers!
