  2. Allegro X Capture CIS
  3. Method to export object and net name
  • Subscribers 50
  • Views 10132
kakri
kakri over 4 years ago
Is there any way to export Object ID and Net name for the whole ORCAD design?
Objective: There can be errors when there a inter-sheet reference is misplaced or misspelled. This will be exhausting if the design contains 100s of pages. If the Object ID and Net name of the whole design can be exported to excel sheet, it will easy to verify the whole design much easier.
  • rg13
    0 rg13 over 4 years ago
    You may want to try 'Tools > Export Properties'.
    It has both the options: Part Properties and Flat net properties.
    Report created by it, has ID column.
  • kakri
    0 kakri over 4 years ago in reply to rg13
    Thanks for the reply.
