  2. Allegro X Capture CIS
  3. OrCAD - Tip of the Week: Rename a user-defined property...
  • Subscribers 49
  • Views 2320
OrCAD - Tip of the Week: Rename a user-defined property in the design
DesignTech
DesignTech over 4 years ago
Often, you need to change a property name for all parts in your design. There are different parts in the design with the same property name but with different property values. How can you rename a property without losing its value? It is much easier said than done.
Capture offers a direct Rename Part Property utility under the Edit menu. Now, renaming a property is as simple as it sounds.
Team DesignTech
Cadence Design Systems
