  2. Allegro X Capture CIS
  3. OrCAD capture differential pair greyed out problem
  • Subscribers 51
  • Views 11239
ichliebedich
ichliebedich over 4 years ago
Hi All
I use orcad capture 17.4 lastest hotfix.
why my differential pair menu greyed out?
how can I re-activate that menu?
regard
  • steve
    0 steve over 4 years ago
    This is usually happens if you have enabled a Constraint Manager flow. (PCB - Constraint Manager). If you have then you would typically use CM to create differential pairs (select the two netnames in CM and right click - Create Differential Pair). If you have enable a CM flow and want to go back the only choice you have is to close Capture and in the directory where the design file is (filename.dsn) will be a filename.3sav (a backup of the dsn when you enabled CM) which can be renamed back to filename.dsn. You can then continue with non-cm enabled flow.
