  2. Allegro X Capture CIS
  3. Failed to import schematic from EAGLE. sch to ORCAD
  • State Verified Answer
  • Subscribers 50
  • Views 12081
ZhengweiX
ZhengweiX over 4 years ago
Hi Folks,
I need to import schematic from EAGLE .sch file to ORCAD, but as I tried, it failed with tips "Warning (INI): Char Replacements 'PinNumbers' - FROM//TO charsets are different sizes".
Anybody suffer this too? Any suggestion will be appreciate.
BTW, ORCAD 17.2 and EAGLE 9.6.3 are used in this case. I also tried EAGLE PCB translator in ALLEGRO, it works and import PCB file successfully.
  • DS1995
    DS1995 over 4 years ago in reply to ZhengweiX +1
    Enable the option View > Session Log Window. Now the first entry of the window tells you the exact path of the INI file getting loaded.
  • ZhengweiX
    ZhengweiX over 4 years ago +1 verified
    Guys, fixed by installing the latest Hotfix
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago
    Please check, the number of characters before and after the // for a Replacement configuration variable in the (.INI file) are not equal.
    It MUST be
    For instance, this directive
    PinNumbers=abc//xyz
    Will instruct to replace a with x, b with y and c with z for all pin numbers
  • ZhengweiX
    0 ZhengweiX over 4 years ago in reply to SandeepVarrier
    Thanks Buddy,  could you guide me how to locate .INI file? I am not sure if I got the correct one.
  • DS1995
    0 DS1995 over 4 years ago in reply to ZhengweiX
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago in reply to DS1995
    %home%/cdssetup/OrCAD_Capture/17.4.0/ type in the following in the windows RUN command  (Keyboard shortcut: Windows Key +R )
  • ZhengweiX
    +1 ZhengweiX over 4 years ago
