  2. Allegro X Capture CIS
  3. adding schematics library
  • Subscribers 51
  • Views 8224
myil17
myil17 over 4 years ago
I would like to add a library to schematics. What's the easiest way to do it?
Regards
    Andrew Beckett over 4 years ago in reply to Andrew Beckett +1
    For some reason your reply: I am using Allegro Design Entry HDL. My problem is I have two different designs and same libraries. Though I have same library, they hold different cells. how can I change…
    The first step is to provide enough information about your problem. You didn't even say which tool you're using (or the version).
    If it's Virtuoso Schematic Editor, to add a library you'd use File->New->Library in the CIW.
    I am using Allegro Design Entry HDL. My problem is I have two different designs and same libraries. Though I have same library, they hold different cells. how can I change the cells and make them exactly same?
    seems to have been deleted. Anyway, that gave the pointer that your question is in the wrong place, so I've moved it to a more appropriate forum than Custom IC Design.
