  2. Allegro X Capture CIS
  3. OrCAD - Tip of the Week: Navigating a hierarchical desi...
  • Subscribers 49
  • Views 3111
OrCAD - Tip of the Week: Navigating a hierarchical design
DesignTech
DesignTech over 4 years ago
Did you also descend into a hierarchical block and then wonder what page you are seeing? If the circuit under a hierarchical block is a multi-page design, Capture does not always open the first page on descending into the block.
Well, you can control the above behavior. You can choose to open the first page of the schematic folder or even be asked to select the desired page each time you descend into a block. Do this Schematic Descend setting using Options > Extended Preferences > Schematic.
Team DesignTech
Cadence Design Systems
